jl audio 6w3v3 sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122086
Printed Date: May 14, 2024 at 8:48 AM
Topic: jl audio 6w3v3 sub
Posted By: cvame
Subject: jl audio 6w3v3 sub
Date Posted: June 01, 2010 at 3:02 AM
Does any one have any experience with the JL Audio 6W3v3 6" sub? Im considering a couple of these for mid bass in the 70 - 300Hz range. Any information or opinions would be greatly appreciated, Thanks
Posted By: remarkable53
Date Posted: June 09, 2010 at 3:44 PM
excellent choice if given the correct amount of power and crossovers set correctly which you seem to have a handle on. Are you planning on having them in any type of enclosure or utilized as an infinite baffle? All in all an excellent speaker and you really can't go wrong. I would however be somewhat cautious about setting the high pass @ 300hz but would experiment a bit. I believe the driver is certainly capable of working in that high of range but "working" and sounding good is two different things imho....
------------- remarkable53
Posted By: cvame
Date Posted: June 09, 2010 at 10:24 PM
Thanks for the reply remarkable, Im trying to decide between either a Rockford 8" or the JL 6.5" to rock serious mid bass.. Ive never heard these little subs for myself so i dont know how good they sound. I meant to write 70 - 150Htz range, dont know why i put 300 (brain fart) Im hopeing to lasso a JL HD900/5 for the powerplant. As for the enclosure if i go with the JL's, either a sealed kick panel or a sealed door pod? I guess my question should be is, "will they rival a fosgate P2-8" ??
Posted By: roadshop570
Date Posted: June 11, 2010 at 12:31 AM
Even thouth the JL is smaller is still is a stronger speaker, I used 4 JL 6wo a couple of years ago in a sealed enclosure it it was louder and cleaner than most 4 10" speakers that guys had they only rated 60watts rms but were awesome on the JL 250/1 d-class so in my opinion the 6w3v3 will be superior from sub or mid-bass range. ------------- Chadillac
Posted By: cvame
Date Posted: June 11, 2010 at 1:53 AM
Thanks for your opinion roadshop, i appreciate it. I'm really leaning towards the JL's now. Id just like to hear them first, tryin to find a shop in my area (phoenix) that stocks them.
