can you eliminate audio whine?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=122565
Printed Date: June 10, 2024 at 5:35 PM
Topic: can you eliminate audio whine?
Posted By: MacGuru
Subject: can you eliminate audio whine?
Date Posted: July 07, 2010 at 7:17 PM
The car is a 2006 MINI Cooper. I have the following audio set-up.
JL Audio Components (up front)
JL Audio HD 900/5
JL Audio stealth box w/subwoofer
Pioneer AVIC -N3
I have my car in a shop right now and they are saying that the MINI (BMWs) are prone to some audio whine. As demonstrated by the installer (using a stethoscope like devise), all speakers and amp (JL audio) were disconnected from the head unit. No power to the amp, but the power cable was still connected. The installer checked all power cables, rca's, etc. and showed me that everything is installed correctly (proper grounding, etc.). The installer even tested a different head unit and the whine is still there. So, we ruled out the existing head unit (Pioneer).
What we discovered is there is still a slight whine coming from under the battery compartment. The whine gets amplified after powering up the amp, but can be dialed out of the speakers using gain control. However, the whine still remains present even though it's not coming through the speakers.
Any thoughts or suggestions are greatly appreciated.
Posted By: i am an idiot
Date Posted: July 07, 2010 at 7:25 PM
If it is not coming from the speakers, I can not help you.
Posted By: leprechaun1874
Date Posted: July 07, 2010 at 7:50 PM
The easiest way is to try gruond loop isolators. Im sure there is some one her who can tell you how to eliminate the whine without them but it's what I have used in the past.
Posted By: dasbogie
Date Posted: July 07, 2010 at 7:53 PM
Is this car supercharged? We had a mini and with everything off except the engine we could hear a wine/somewhat whistling noise but it was definitely coming from the engine. The customer believed it was our installation but when we showed him everything was off and it was not coming through the speakers it finally convinced him it was under the hood, not in the car.
------------- Advanced
Posted By: MacGuru
Date Posted: July 07, 2010 at 8:14 PM
BTW, the stethoscope device was used to isolate the location of the whine. Which is how we determined it was coming from under the battery.
Definitely not coming from the engine. The battery is located in the rear of the car (center) for a MINI. The installer has tried ground loop isolators, said he rarely if ever has to use them. He even ran high quality RCA's (twisted and shielded), and all cables are on the opposite side of the battery power lead going to the front of the car. The installer even tried running the RCA's outside the car to see if was interfering with other OEM wires. So, we've ruled out the RCA's.
Posted By: MacGuru
Date Posted: July 07, 2010 at 8:16 PM
Yes, my MINI is supercharged.
Posted By: MacGuru
Date Posted: July 07, 2010 at 8:30 PM
With everything connected, the whine will come through the speakers at a slightly higher volume (which would make since if the amp is not the source). The whine will slightly increase with revving the engine, but not by much. The goal is to eliminate the whine all together. So, we tracked down the source as described above.
Thanks in advance for your help.
Date Posted: July 07, 2010 at 9:02 PM
If you turn the gains of all amps all the way down, do you hear any whine coming from any speaker?
Posted By: MacGuru
Date Posted: July 07, 2010 at 9:33 PM
If we adjust the gains all the way down, the whine is almost completely gone. Still there, but very slight.
Posted By: MacGuru
Date Posted: July 07, 2010 at 9:34 PM
One thing I forgot to mention;
My car was recently in for service for a radiator fan replacement. When I got the car back, the whine noise was gone. At first I thought, nahhh can't be! The stereo was off, as the service required disconnecting the battery. Since it was off, I never turned it on. The whine was completely gone. Got home, turned the car off. Went back out later to drive into the city and no whine. Again, I had not turned on the radio. I was enjoying the whine free ride. As you might expect, the second I turned on the radio, the whine slowly came back.
This is the reason why I having the installers take a second take at eliminating the whine. It's got to be in the stereo wiring or grounding, but it's definitely not related to the MINI.
Posted By: MacGuru
Date Posted: July 07, 2010 at 11:06 PM
While doing more research on how to resolve this, I came across a couple of responses from MINI owners that stated to put a capacitor on the alternator. What does this mean? Has anyone done this? If so, details please...
Posted By: MacGuru
Date Posted: July 08, 2010 at 12:12 PM
Update:
The whine only appears after the amp is turned on. The whine is now been minimized significantly, but is still present. The previous isolation was resolved by disconnecting the battery and allowing it to sit for an hour.
Another suggestion was to use a capacitor. Any idea what farad rating? Polarized or not? Sorry for all the questions, but I'm new to this.
Posted By: the12volt
Date Posted: July 08, 2010 at 1:00 PM
Try a 500 microfarad polarized capacitor on the alternator. I've used them with great success many times in the past to eliminate alternator whine. From what you've described, it will likely work for you. ------------- the12volt • Support the12volt.com
Posted By: MacGuru
Date Posted: July 08, 2010 at 4:35 PM
Thanks. They are installing one tomorrow. I will let you know how it goes.
Date Posted: July 08, 2010 at 5:00 PM
You're welcome. Koo :) ------------- the12volt • Support the12volt.com
Date Posted: July 08, 2010 at 10:38 PM
500 mic is tiny as far as killing ripple from an alternator, were you meaning to say 5000? Radio Shack sells a 4700 mic cap for less than 5 dollars. I would try one or two of those.
Posted By: jmelton86
Date Posted: July 09, 2010 at 6:50 AM
Why is the alternator doing this, for future reference?
I love MINIs, BTW. I LOVE them. ------------- 2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Date Posted: July 09, 2010 at 7:42 AM
Thanks for the heads up. Actually, I meant to say a half farad. ------------- the12volt • Support the12volt.com
Date Posted: July 09, 2010 at 9:02 AM
Errr... too early for me this morning. A 50,000 microfarad capacitor is what you want. ------------- the12volt • Support the12volt.com
Date Posted: July 09, 2010 at 9:38 AM
500.000
Date Posted: July 09, 2010 at 9:59 AM
500K would definitely do it, but 50K should be more than adequate :) ------------- the12volt • Support the12volt.com
Posted By: MacGuru
Date Posted: July 09, 2010 at 10:05 AM
So would a 1.0 or 1.2 or 1.2 farad be too much? This is what was recommended on a MINI forum.
Posted By: MacGuru
Date Posted: July 09, 2010 at 10:06 AM
Sorry, meant to say 1.0-1.2 Farad.
Date Posted: July 09, 2010 at 10:14 AM
If you can fit it and want to buy it, go for it. It should definitely filter out the ripple. ------------- the12volt • Support the12volt.com
Date Posted: July 09, 2010 at 10:27 AM
1/2 farad = 500K
Date Posted: July 09, 2010 at 12:18 PM
I really meant 50K initially... brain fart :p ------------- the12volt • Support the12volt.com
Posted By: throwback2332
Date Posted: July 09, 2010 at 1:33 PM
Sometime grounding the sheild of one of your RCA's will work.
------------- If it's not custom, then it's not you.
