1 deck, 6 speakers, 2 amps, 2 subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123456
Printed Date: May 31, 2024 at 7:48 PM
Topic: 1 deck, 6 speakers, 2 amps, 2 subs
Posted By: richmane
Subject: 1 deck, 6 speakers, 2 amps, 2 subs
Date Posted: September 10, 2010 at 10:20 PM
I need help with how to wire my setup, I have a 2001 Hyundai XG300L. It has stock tweets, fronts and rears that each have their own factory amps which I have bypassed. I have connected the fronts and tweets together for 2 channels of my Sony XM-460GTX amp using the low level inputs, the rear speakers are connected to the head unit, and the subs are connected with the RCA outs from head unit to amp; amp to speakers, sharing the same speaker outs, 2+ and 2-. I have a Bazooka 2 ch. amp I just got, would anyone be able help me with the proper wiring to allow my Sony 4 channel to feed my front & tweets and my rears, and using the bazooka for the subs? Thanks!
Posted By: trying my best!
Date Posted: September 10, 2010 at 10:42 PM
first of all whats the channels on the other amp? and remember highs and lows always need their own juice! if the other amp is a 4 channel also you can hook up the front and rears 2+,2- and just run your tweets inline with those! but keep in mind the WATTS to much and you blow your sound and not enough it sounds muffled!
