amp and sub combo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124158
Printed Date: May 22, 2024 at 11:46 PM
Topic: amp and sub combo
Posted By: cal620
Subject: amp and sub combo
Date Posted: October 27, 2010 at 10:02 PM
What would be the best way to wire these subs with this amp? Could i wire them to 4 ohms load to get a good sq? I have wiring diagrams to wire them to a 4 ohm load or 1 ohm load but dont know which one i would get the best sq out of. Im not looking for a ton of bass just good sq.
KAC-9105D Class D car amplifier
Number of Channels     1 - Mono
RMS Power (4 ohms)     500 watts x 1 channel
RMS Power (2 ohms)     900 watts x 1 channel
RMS Power (1 ohm)     >900 watt x 1 channel
Bridged RMS Power     Not Bridgeable
Total RMS Power Output     900 watts
Peak Power Output     1800 watts x 1 channel
Total Peak Power Output     1800 watts
Minimum Impedance Unbridged     1 ohms
Pioneer Champion subwoofers
Subwoofer Size     12"
Voice Coil(s)     Dual
Impedance (per voice coil)     4 ohms
RMS Power Handling     400 watts
Peak Power Handling     1400 watts
Posted By: i am an idiot
Date Posted: October 28, 2010 at 10:08 AM
A 4 ohm load will be 4 times easier on your amp.  Wire it like that and if you have enough bass, then leave it that way.  If it is not enough bass you may have to wire them to 1 ohm.
Or you could do both:
https://www.the12volt.com/relays/relaydiagram27.html
Posted By: agraves1
Date Posted: October 28, 2010 at 7:44 PM
If you are going for sq just go with the 4 ohm setting. I would think your system would be pretty unbalanced with 900 watts of bass unless you have your other speakers amplified. If you are just running your other speakers of your head unit then 500 watts of bass is more than enough.
MECP Advanced
Make your life easier and buy a DMM.
Posted By: lsd972
Date Posted: December 05, 2010 at 11:44 PM
Hello
Is that the pioneer Ts-308D4 ?
Because I would like to install 2 like this one and I wonder which amp I should choose to be able to extract all the subwoofer power ? I saw some nice hifonics
Hifonics HFi1500D
Hifonics Brutus BRZ1200.1D
Hifonics Brutus BRZ1700.1D
Hifonics HFi1000D
Thanks in advance guys
LSD972
Posted By: haemphyst
Date Posted: December 06, 2010 at 10:57 AM
To the OP... I agree with everybody else. Go with 4-ohms, the amp will run cooler with less distortion, and your damping will be higher. You will also have less than a 3dB difference in output between the 4-ohm load, and the 1-ohm load.
lsd972 wrote:
...nice hifonics...
Contradictions in terms, there, amigo. HiFonics USED to be close to OK, stuff. But now? Mid-range Swap-O-Rama gear, at best.
