looking for amp suggestions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124185
Printed Date: May 23, 2024 at 8:43 AM
Topic: looking for amp suggestions
Posted By: newnick
Subject: looking for amp suggestions
Date Posted: October 29, 2010 at 7:55 PM
I have a 05 F150 crew cab (4 door) that I've just replaced the head unit and speakers in and am ready for more power. I used a JVC XR810 HU, Infinity 680.9cs components front door, and 682.9cf coaxial rear door. I'm looking for a decent four channel amp that sounds good and is reliable.
I'd also like to know the best place to mount it. I'm thinking under a front seat, leaving the area under the back seat free in case I want to add a sub later. I do have bucket seats with a large center console that has alot of room inside, more than enough for a amp, but I'm concerned with air circulation. Thought maybe some would have some thoughts on that.
Posted By: mrm1776
Date Posted: October 29, 2010 at 8:59 PM
Infinity makes a pretty decent 4 channel. Can't remember the exact model, but it's got a pretty small footprint too. I believe it's a Kappa series.
------------- MECP Basic Installation Tech
Certification ID: CEA195600
Pioneer AVIC-X920BT
Polk Audio DXi 6500 - front
Rockford Fosgate Power T1693 - rear
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Posted By: pitoaudiovisual
Date Posted: October 30, 2010 at 11:35 AM
Oxygen Audio has a good amp 0A940.4. Very reliable and doesnt overheat
------------- Confidence is the key to any project!!
Posted By: soundnsecurity
Date Posted: October 30, 2010 at 5:32 PM
soundstream stealth 4 channel will do perfectly.
Posted By: mrm1776
Date Posted: October 30, 2010 at 6:53 PM
I think I've figured out that you love Soundstream... Haha. Seems like you're constantly recommending them. Might have to look into them a bit more and see what all the fuss is about. ------------- MECP Basic Installation Tech
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Posted By: newnick
Date Posted: October 30, 2010 at 8:50 PM
I looked at the Kappa, looks like a good amp but if I put it under a front seat I won't be able to access the controls. I also looked at the Oxygen but there website looks a little cheesy, kinda Chinese if you know what I mean. The specs don't look all that bad though. I'll have to check out the soundstream.
I 'd rather go with a name thats been around a while that others have had good luck with.
Posted By: mrm1776
Date Posted: October 30, 2010 at 9:03 PM
Remove front seat to do install and initial tuning. Once I do the initial tuning, I VERY rarely have to access it again. I take care of all the tweaks from the head-unit.
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Posted By: newnick
Date Posted: October 31, 2010 at 5:51 AM
I figured thats what most people do if the controls are on the top. Seems like the most logical thing would be to have all the wires coming in on the same side also like towards the front of the seat so they don't get hit by feet from the back.
Posted By: mrm1776
Date Posted: October 31, 2010 at 7:08 PM
I typically will cut a hole in the carpet and run all of my wires up through that hole and put the amp back down on top of that so that the wires come out from under the amp. Makes for a very clean install. I usually space the amp up a little bit off of the floor/back of seat when doing this with plastic spacers.
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Posted By: newnick
Date Posted: November 06, 2010 at 8:47 AM
So what is a exceptable way to mount a amp under a seat? Where is a good place to attach the ground wire?
I'm going to have to raise the amp up some to clear a a/c vent.
Sorry about the noob questions but the last time I put a amp in a auto was in 1978 and back then I just put it in the glove box using wire nuts to make connections.
Posted By: mrm1776
Date Posted: November 06, 2010 at 10:14 PM
Well definitely don't use wire nuts. Those are never advised for multi-strand applications.
As far as mounting it under the seat you can secure it straight to the floor... maybe using some wood blocks to space it up above the vent that you're worried about. I pop some silicone on the underside of the body if the screw happens to pop through the metal. As far as grounding it... the best way is straight to the chassy. I usually advise finding a nice spot of metal, sanding it back to bare metal, and popping a self-tapping screw through with a star washer attached. ------------- MECP Basic Installation Tech
Pioneer AVIC-X920BT
Alpine MRP-F300
Alpine MRP-M500
Alpine SWR-1242D
Posted By: newnick
Date Posted: November 07, 2010 at 6:05 AM
I would not use wire nuts now, but back then it worked just fine.
I found a better place to mount the amp than under the seat. Apparently there is enough room behind the back seat even though it doesn't look like there is any room. I went and talked to the guy's at a local shop and that was the first place they mentioned. I also did more searching on the net and found some threads with pics and it looks like there is room for several amps behind the seat.
Now I just need to decide which amp to get, there are to many choices.
