my car system weighs too much
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=125561
Printed Date: May 13, 2024 at 10:10 PM
Topic: my car system weighs too much
Posted By: still_walkin
Subject: my car system weighs too much
Date Posted: January 09, 2011 at 12:26 AM
i have a mtx box that weighs 100 lbs and two alpine type r that weigh 24 lbs each and my amps racks etc wieghs in around 60lbs total so thats too much weight when you add two people in the back and a full gas tank. so my question is i want something that same in sound or louder light but one sub.
what i want to use for the fronts doors rears is (2)PDX-F4  and the subs to buy in question(1)  MRP-M2000
my current system
alpine 4x6, 5 1/4, 6x9 for the pdx f-4
replacement subs MRP-M2000
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
Posted By: knotdrummer88
Date Posted: January 09, 2011 at 1:53 AM
you could go with some shallow mount subs, that could lighter, or maybe look at the weights of three tens? or eights? similar cone area but smaller sub, i dont know just an idea. and for the box you could build a fiberglass enclosure
Date Posted: January 09, 2011 at 1:55 AM
im sorry, for some reason i thought you said you had twelves! sorry about that, but the same idea can still apply
Date Posted: January 09, 2011 at 2:05 AM
i have 12s and the shallow mount subs i heard bad things about them and in lack of bass . but i might try the fiberglass desgins and see what i come up with
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
Date Posted: January 09, 2011 at 1:28 PM
cool man, post again of your progress
Posted By: soundnsecurity
Date Posted: January 09, 2011 at 3:07 PM
first, the weight difference between a 12 and a 10 of the same sub is typically maybe 2 pounds more or less. if you want to save weight then go with a single 12 or 15 in a fiberglass box and you should be able to cut the weight by maybe a third. other than that you would have to change your entire setup with saving weight as your main priority.
Date Posted: January 10, 2011 at 10:36 AM
So heres the update im going to get one alpine type x size 12 and have the measurements 32*15*8=1.54 sealed. I rather have ported but I couldn't find a small ported box as for amps I'm going to get the ones posted above .before I make my final decision I'm going to google the items to see if its a weight difference. If its less than 40 I'm going to leave my setup be.
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
