2007 toyota avalon
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126203
Printed Date: June 14, 2024 at 6:22 PM
Topic: 2007 toyota avalon
Posted By: pipes15
Subject: 2007 toyota avalon
Date Posted: February 18, 2011 at 12:43 PM
Hey guys, I am installing two subs and an amp in this vehicle. Can anyone tell me where the easiest location to tap into for my line inverter for my amp. I am keeping my factory head unit. Or what colors are what behind the radio? any help would be great. also has anyone taken out the factory radio, if so do you have to re enter the lock out code if you unplug it? thanks again.
------------- PIPES
Posted By: Mike M2
Date Posted: February 20, 2011 at 9:34 AM
There is no "code" on a Toyota radio like there is on a Honda, just plug it back in. Most Avalons have a factory amp under the passengers seat. Slide the seat forward and you will see the amp and the plugs. LR speaker- yellow+ black-, RR speaker- red+ white-. If there's no amp they will be in the PKP or behind the radio.
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: pipes15
Date Posted: February 20, 2011 at 9:44 AM
Thanks mike for the help. I found the yellow and black wire in the DKP!
------------- PIPES
