2002 alero monsoon audio system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126295
Printed Date: June 09, 2024 at 8:39 AM
Topic: 2002 alero monsoon audio system
Posted By: aaroncc
Subject: 2002 alero monsoon audio system
Date Posted: February 24, 2011 at 3:15 PM
hello everyone! now ive been a mechanic. all my life if you need a two stage nitrous motor bulit bulletproof im ur man! however im not to keen on this stereo system with a monsoon amp.My problem is i cant get that whine out of my speakers.My powerwire is ran to the battery with a fuse link.My ground is to the rear strut mounting bolts and is very tight with all paint stripped off.I do have music playing through 2 6x9 aftermarket pioneer speakers.I have been lookin on internet and found that a filter of some sort will work i think a noise filter?????i have a stock hu a crunch 600.2 amp  and speakers above...or will it be easier to bypass that amp all together.thank you so much for any and all help!
if ur not part of the solution..ur part of theproblem......
Posted By: jpadj22
Date Posted: February 24, 2011 at 5:28 PM
Try this, grab a Speaker wire wire (any wire will do) loOsen a screw from the back of the radio. Tie the wire around the screw then tighten it. Now wrap your the wire on your rca plugs that go to ur amp. That works for me hope it helps.
No better feeling then getting a remote start to work right!
Posted By: jpadj22
Date Posted: February 24, 2011 at 5:35 PM
I forgot to tell u to make sure u do it at the radio not at the back for this to work. Also noise filter have NEVER worked for me.
Posted By: jpadj22
Date Posted: February 24, 2011 at 9:29 PM
Im sorry i missed the stock hu. Then just ground ur rca's where ever ur getting the output from should work.
Posted By: Velocity Motors
Date Posted: February 25, 2011 at 7:44 AM
I whine coming from all 4 speakers or just the 2 Pioneer rears ? What did you do for the front speakers ? Amp or just using the Monsson amp to power them ?
