double baffle for hdc3 18
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127231
Printed Date: May 13, 2024 at 8:45 PM
Topic: double baffle for hdc3 18
Posted By: knotdrummer88
Subject: double baffle for hdc3 18
Date Posted: May 05, 2011 at 12:01 AM
For my hdc3 Im building a box which is approx. 40"x22.5"x16.5. its just over 6^3 ft. my question is, for my double baffle is it ok if the top half is actually two pieces? cuase im runnig out of wood, but i have a long piece of mdf that i could cut into two pieces to add ontop of the single battle. feedback is greatly appreciated, thank you.
Posted By: sthrnbmpn
Date Posted: May 05, 2011 at 1:35 PM
put a 45 bevel cut on ur joint an then liquid nail, clamp an a few screws in both baffles.
once liquid nail sets , the wood will tear apart bfore the glue will
hdc arent that common of a sub , thats kinda what i like stuff that most people never heard of, oh yeah gorilla glue is pretty gd stuff too
u could also cover the joint with another piece mdf an give it a stepped up look to the baffle
------------- 1000 watts of lp, now need sum hp an mids
Posted By: soundnsecurity
Date Posted: May 07, 2011 at 4:45 PM
not ideal but it will work if you do it right. plenty of liquid nails, screws and clamped tight for at least a day to make sure you have a tight bond between the two layers.
