sub suggestions for sony amp.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127240
Printed Date: May 23, 2024 at 8:11 AM
Topic: sub suggestions for sony amp.
Posted By: pesti13nce
Subject: sub suggestions for sony amp.
Date Posted: May 05, 2011 at 8:28 PM
I recently got my hands on a Sony XM-GTR2022 amp, and a pair of Polk momo 12's. Well after 3 days I found out one didn't work at all. So I then wired up the single working sub in a 12" sealed box i had, and after another day I blew the sub, or overheated it, or something not sure to be honest, it still hits but it's very "hollow" sounding like something in the unit separated.
I'll admit i found it on CL bought them installed them and knew nothing about the gains or anything had it cranked and I'll say i payed for it. The only thing I seemed to do right in the setup was run the proper wire size via suggestions on this site.
TLDR Sony amp:
Max Power 1200W x 1
RMS Power output @ 2 ohms: 600W x 2
RMS Power output @ 4 ohms: 250W x 2
Variable 50-300Hz low pass filter with 12dB per octave slope
Low boost 0-10dB (40Hz)
What sub suggestions for this amp, or better yet what would be acceptable watt rms/peak for optimal sub selection?
I've learned a bit more about not setting the amp gains up all the way like an idiot.
Date Posted: May 05, 2011 at 8:29 PM
Ha, forgot to add car info it's an 01 Grand Prix.
