swap factory with aftermarket amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=127633
Printed Date: October 31, 2024 at 6:49 PM
Topic: swap factory with aftermarket amp
Posted By: tak4
Subject: swap factory with aftermarket amp
Date Posted: June 14, 2011 at 3:28 PM
So after many problems to install my Alpine Double din into my IS250; I have decided to just power my stock speakers with a aftermarket amp and power the amp with my DD. But the problem is, is that the 2006 IS250 has 13 speakers. How would I go about wiring them to my 4ch amp?
I heard some people say that they dont wire the tweeters but I was wondering how would the best way to wire it?
Here is a wire diagram
posted_image
I was thinking of for the most part to wire the main speakers like this
posted_image
It seems like some speakers are wired to the same pin, on the diagram.
But can some one with more knowledge help me out?
Posted By: tak4
Date Posted: June 17, 2011 at 3:00 PM
anyone know?
Posted By: talarchevy
Date Posted: June 22, 2011 at 2:08 PM
i would first test the impedance of the stock speakers leaving the factory amp, write them down, check you aftermarket amp and see if its 2ohm stable in stereo(it should) I wouldnt mess with the center or factory sub, if your using the factory deck i would check into using a LOC,
Go BIG or go Home                                    it might not be broke, but lets fix it anyway
Posted By: blanx218
Date Posted: June 22, 2011 at 8:35 PM
did you by chance purchase a toyota/lexus amp integration harness for your initial install? I use them all the time and all speakers work everytime. the metra part number is TYTO-01
