jl svc with apline dvc and thunder 4501
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128106
Printed Date: May 15, 2024 at 6:31 AM
Topic: jl svc with apline dvc and thunder 4501
Posted By: davewells
Subject: jl svc with apline dvc and thunder 4501
Date Posted: August 01, 2011 at 12:28 PM
Hello,
I did try to search to see if there was information on this, but I feel that I did not find a definitive answer.
I have:
Alpine 1042D - DVC 4 ohm 10" Sub
JL JL10W3V34 - SVC 2 ohm 10" Sub
MTX Thunder 4501 amp that can do
1 -2ohm channel at 500 watts
2 - 4 ohm channels at 250 watts.
The amp specs say that it can actually produce
619 watts for a single 2 ohm connection
or 347 watts x 2 for a dual 4 ohm connection.
I really don't know much about this stuff at all, only what I have read online.
Is there any way that I can use all of this stuff together without having to buy anything else?
I am more concerned with good sound musically, as opposed to hammering bass.
Thanks for reading my post.
Posted By: ac0j
Date Posted: August 02, 2011 at 11:24 PM
you can only use one sub, there is no way to wire the two subs you have to anything that the amp can handle if it is only stable to 2 ohms. Either wire the DVC parallel or use the 2ohm svc.
