1999 ferrari 360 wiring.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128216
Printed Date: March 15, 2026 at 10:44 AM
Topic: 1999 ferrari 360 wiring.
Posted By: bwhite21
Subject: 1999 ferrari 360 wiring.
Date Posted: August 11, 2011 at 6:46 PM
Does anyone have the wiring diagram for a 1999 ferrari 360 modena? Directechs was no help! I wired everything up the same way the previous install was done, but the head unit began to smoke at the heatsink. Obviously something was wrong lol. Thanks guys
Posted By: oldspark
Date Posted: August 11, 2011 at 8:25 PM
That sounds like speaker (impedance) fault or similar, not the vehicle's wiring.
12V is 12V and it cannot cause HUs to smoke (except via incorrect polarity or HU fault etc).
And although a bad ground can cause HUs to smoke, that will rarely be from the heatsinks (since the ground won't pass the power unless there are enough alternate paths.
And a bad +12V should cause the +12V supply to smoke.
Posted By: bwhite21
Date Posted: August 12, 2011 at 9:56 AM
Does anyone have a wiring diagram for the speakers?
Posted By: bwhite21
Date Posted: August 12, 2011 at 10:05 AM
Ive got 4 speaker wires, green, gray, purple, PURPLE / black
Posted By: tonanzith
Date Posted: August 12, 2011 at 10:07 AM
I did a 2001 and if it is the same here is what I had,
Battery          YELLOW          (+)          RADIO HARNESS
Accesory          RED          (+)          RADIO HARNESS
Ground          BLACK          (-)          RADIO HARNESS
Dimmer          ORANGE          (+)          RADIO HARNESS
Power Antenna          BLUE          (+)          RADIO HARNESS
LF Speaker (+)          WHITE
LF Speaker (-)          WHITE/ BLACK
RF Speaker (+)          GRAY
RF Speaker (-)          GRAY/BLACK
Steering Cntrls          NO
Speed Cntrl          NO
Radio Security          YES
Gary Sather
Posted By: bwhite21
Date Posted: August 12, 2011 at 10:43 AM
ok well wired everything back up, still no sound from the speakers.
