2004 chevrolet epica/ pac swi jack
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128262
Printed Date: March 14, 2026 at 8:11 PM
Topic: 2004 chevrolet epica/ pac swi jack
Posted By: mikejc
Subject: 2004 chevrolet epica/ pac swi jack
Date Posted: August 16, 2011 at 9:07 AM
Im putting a Alpine CDA-9886 into a 2004 Chevrolet Epica, no problems with installing the deck, but having an issue with the steering wheel audio controls. Im using a PAC SWI-JACK and cant find the hookups for the steering wheel intergration. Supposed to be the same as an AVEO or Suzuki Verona, and it takes a DAEWOO harness. Any help would be greatly appreciated. What i have left is a WHITE/ blue wire, and a green wire left in the factory radio harness. Green is putting out 0.7V on multi meter when the key is in accesory position.
Posted By: casofwaco
Date Posted: August 16, 2011 at 10:15 AM
  • I looked up the suzuki verona and this it what it said to do
  • Connect the SWI-JACK's White wire to Pin 16 (WHITE/ Dk Blue)
  • Connect pin 13 (BLACK/ White) to chassis ground. Cut Purple wire and insert 10k ohm resistor in series of the purple wires.
    BAD Boy Emergency Vehicle Lighting
