2001 Cavalier Receiver Installation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12853
Printed Date: May 19, 2024 at 5:05 AM
Topic: 2001 Cavalier Receiver Installation
Posted By: pjgill
Subject: 2001 Cavalier Receiver Installation
Date Posted: April 28, 2003 at 1:23 PM
I'm having some trouble removing the factory receiver from my 2001 Chevy Cavalier. I also need some advice for removing the covers from the front door speakers. Any advice would be appreciated!
------------- P Gill
Posted By: jeremy1
Date Posted: April 28, 2003 at 2:04 PM
cavaliers are fun (disconnect the battery) there is a screw on both sides of the dash behind the end caps ,1 screw in the defrost vent 2 under the vent ,possibly one above the spedomiter,a few in the top of the glove box and two gold ones in the back of the glove box then the top of the dash carefully pops up (watch the air bag at all times) then there are 4-6 screws across the top of the front dash piece before it pops off .be carefull and be gentle...good luck
Posted By: TURBOTOM
Date Posted: April 28, 2003 at 3:45 PM
YOU WILL ALSO NEED TO RUN AN ACCEESSORY WIRE AS THE NEW GM VEHICLES DON'T HAVE ONE BEHIND THE DECK
Posted By: Blazermedic
Date Posted: April 28, 2003 at 4:02 PM
You might need an accessory wire if your cavalier has the new GM Databus. Here's an easy way to tell. Turn the key and open a door. If the chimes are coming from the speakers, then you have the databus. If they are coming from somewhere behind the central dash, then you don't and the acc. wire will be in the harness.
Cary
Posted By: bobs94
Date Posted: April 28, 2003 at 6:32 PM
Is this the same for the 2000 Cavalier z24? What do you do about the factory alarm led that's in the radio?
Posted By: Velocity Motors
Date Posted: April 28, 2003 at 11:26 PM
Front Door Panel Removal The speakers are a 4 x 6 OEM Stereo Removal ------------- Jeff
