home made 3 way passive crossover
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130684
Printed Date: May 15, 2024 at 10:18 AM
Topic: home made 3 way passive crossover
Posted By: gehlsurf
Subject: home made 3 way passive crossover
Date Posted: February 20, 2012 at 9:48 PM
Ok, I'm sure this has been gone over before, I read about 3 articles on various sites about this, so kinda have my head somewhat wrapped around it. But could somebody please refer me to post on here or anywhere to actually see a system put to this? I still have some questions, like.... it seems with a 2 channel amp, bridged, I could have 4 tweeters, 4 midranges and 2 subs? With a 4 channel amp, add 2 more subs!! Is this possible, or am I missing something? And where can I basically..... sigh, hate to say it, but "steal" some one's simple already bought design and mess around with it?
Posted By: DYohn
Date Posted: February 24, 2012 at 9:57 AM
In general, one channel of am amp supplies one speaker system and subwoofers require their own channel. You really do not what to build a 3-way passive system where one of the speakers is a subwoofer. Please describe the system you want to end up with. ------------- Support the12volt.com
Posted By: gehlsurf
Date Posted: February 27, 2012 at 10:54 PM
Ah, ok, I didn't get that from my buddy, who used to build these. He said he would use the channel of the amps for highs and mids, and then bridge the sub off of the same output, so basically, how I understood it, one sub for each pair of channels. His subs were typically only 8's or at max 10's.
Posted By: pts760
Date Posted: February 28, 2012 at 2:40 AM
That amp must not have had a long life. That is way to much stress on a channel. Must like the smell of mystic smoke
------------- I drink current, eat ohms, and bleed voltage
Posted By: DYohn
Date Posted: February 28, 2012 at 9:55 AM
You're talking about a tri-mode setup. This was fairly common in the 90's for low-budget installations, but is not a setup I recommend except when absoltely necessary. Amps are just too cheap these days to set up a marginal system like that. But if you must, look for a stereo amp that says it is "tri-mode capable" and make sure you are using 8-ohm or higher speakers all around. ------------- Support the12volt.com
Posted By: gehlsurf
Date Posted: February 28, 2012 at 7:51 PM
Ok, that makes sense, it was in the 90's, Ok, cool, that's pretty much the answer I was looking for, because the tri mode thing kinda threw me off, and I suppose they would have to be fairly high ohms. OK, thanks!!
