still confused on wiring 2 dvc subs.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131810
Printed Date: March 05, 2026 at 3:42 PM
Topic: still confused on wiring 2 dvc subs.
Posted By: j324
Subject: still confused on wiring 2 dvc subs.
Date Posted: July 12, 2012 at 5:15 PM
Okay i have a saz-3000d which is a mono amp and has 2 positive inputs and 2 negative inputs. I am trying to wire 2 dvc subs that are 1 ohm and i am trying to wire it to 1 ohm. could someone please describe on how to do this.
Posted By: KPierson
Date Posted: July 12, 2012 at 5:31 PM
Wire the coil of one voice coil in series with the other voice coil (positive to negative) on each sub. This will create (2) 2 ohm subs. Parallel the two subs for a 1 ohm load.
The amp has two + and two - for convenience - they are internally connected.
Kevin Pierson
Posted By: KPierson
Date Posted: July 12, 2012 at 5:39 PM
posted_image
Kevin Pierson
Posted By: j324
Date Posted: July 12, 2012 at 5:45 PM
Okay so on one sub you run a wire from the negative of one voice coil to the positive of the other voice coil then you run the 2 remaining positive and negative to the amp? And repeat for the other sub?
Posted By: KPierson
Date Posted: July 12, 2012 at 5:50 PM
You got it.
Kevin Pierson
Posted By: j324
Date Posted: July 12, 2012 at 5:53 PM
Okay thanks for the help. And with the double inputs i can just run 1 sub to 1 set of inputs and the other sub to the 2nd set of inputs corect?
Posted By: KPierson
Date Posted: July 12, 2012 at 9:55 PM
Yes
Kevin Pierson
