dual subs and serialing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132866
Printed Date: March 05, 2026 at 6:55 AM
Topic: dual subs and serialing
Posted By: smwilli
Subject: dual subs and serialing
Date Posted: December 03, 2012 at 10:53 AM
This may have been answered before, but searching for these terms only brings up wiring methods.  Anyways, lets say we have 2 4 ohm, SVC subs and a 2 channel amp and it double power as resistance is halved.  lets say power@ 4ohms is 250 wattsx2 and 500X1@ 2ohm
So if I connect these 2 subs @ 4ohm,  without bridging the amp, each sub would see 250 watts.
And if I wire the subs in serial making a 2 ohm load and bridge the amp to 500wX1 channel, wouldn't both subs still see 250 watts, since it 500 watts total divided by the 2 subs?  Or am I over thinking things?
Posted By: i am an idiot
Date Posted: December 03, 2012 at 9:27 PM
Very few 2 channel amps are stable at 2 Ohm mono. The only safe way for you to connect those speakers to that amp is 1 speaker per channel for a 4 ohm stereo load. Or wire the speakers in series for an 8 ohm mono load. You need to do some research on series and parallel circuits. You are calling parallel wiring series.
Posted By: smwilli
Date Posted: December 04, 2012 at 9:08 PM
You are correct.  I guess I should have proofread my post before I posted it.  I do have parallel and series resistance backwards.  Anyways the amp I have is a 5 channel amp (Boston Acoustics 5750) that has 2 channels for the subwoofer, although they are intended to be bridged.  Anyways, the manual does list ratings @ 2ohm and 4ohm, so I would assume it's 2ohm stable.
Posted By: DYohn
Date Posted: December 05, 2012 at 9:56 AM
The Boston Acoustics GT-5750 is, as you say, a 5-channel amplifier. It only has a one channel (mono) subwoofer amp, and it is stable into 2-ohms.
Date Posted: December 05, 2012 at 10:39 AM
It may have 2 sets of terminals for the sub. But the sub channel is only one channel. It may have 2 sets of terminals for ease of connectivity. Both of the + terminals are electrically connected inside the amp. Same for the - terminals. There is no bridging of the 5th channel.
