double din problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135165
Printed Date: April 02, 2026 at 2:28 AM
Topic: double din problems
Posted By: speersy
Subject: double din problems
Date Posted: October 28, 2013 at 6:36 PM
I have wired up a double din video deck using a ford wiring harness in a 2006 ford freestar .The deck is a no name deck.
I have connected all speakers , ground , battery, little light power(conected to dimmer wire) , acc wire.
I have not connected the key 1,can txd,( no stearing wheel controls),back,amp ( no amp), auto antana,(no power antana)
My problem is when I start the car the radio comes on and a picture shows on screen with a bar that shows it is loading but sporatically freezes, some times restarts continuously about every minute.
do I need to connect the key wire and the txd to somthing or possibly together or is there somthing else I may have missed?
thanks
Posted By: i am an idiot
Date Posted: October 28, 2013 at 8:18 PM
You need to get a radio with a brand name on it. Preferably an Alpine, Sony, Kenwood, Pioneer or some brand like that.
Posted By: auto enhancers
Date Posted: October 29, 2013 at 8:59 AM
Very wise words right there. There is a reason the name brand units cost more, it is because they have put time and money into research and product design. That is also the reason you generally don't have issues with these products. That and they have manuals that you can read, understand and are in actual ENGLISH!!
Posted By: speersy
Date Posted: October 29, 2013 at 5:02 PM
Thats all well and fine but this is what I have receved and need to in stall so maybe some info would be helpfull as I need to know if the radio is defective or have I missed somthing.
Posted By: soundnsecurity
Date Posted: October 29, 2013 at 8:30 PM
well, if you have a voltage meter you can use that yo test your power connections for the radio to see if you are losing power at all. if you dont find any problems with the voltage meter then i would assume the unit is defective.
Posted By: powerslave
Date Posted: October 29, 2013 at 10:08 PM
The deck is made by someone, even if it's like huwang, huwei, (examples only, not real deck makers), or whatever... There should be a name and a model number somewhere to post. Remember, SAMSUNG used to be that no-name brand...
Posted By: speersy
Date Posted: October 31, 2013 at 5:31 PM
Ok no name but I disconected all wires except for 12 volts constant ,ground, and accessory and system still reboots on its own.
Am I right in assuming the radio should turn on other than sound and maybe memory?
Date Posted: October 31, 2013 at 6:30 PM
If you do have 12 volts on the Red and Yellow wires of the radio, and ground on the chassis of the radio, and it still restarts you have a defective radio.
Posted By: speersy
Date Posted: November 01, 2013 at 6:08 AM
Thanks Thats what I figuered but wonted an informed opinion before sending back.
