audi antenna adapter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135465
Printed Date: October 31, 2024 at 6:48 PM
Topic: audi antenna adapter
Posted By: pts760
Subject: audi antenna adapter
Date Posted: December 05, 2013 at 8:21 AM
Hello I have a 2004 Audi A4. Metra calls for a 40-VW53 which is for a vehicle with a roof mounted amplified antenna. My car doesnt have a visible roof mount (shark fin) antenna. Can I use the 40-VW10 antenna that I have at the shop or would that degrade my radio reception.
------------- I drink current, eat ohms, and bleed voltage
Posted By: Ween
Date Posted: December 05, 2013 at 7:22 PM
is the factory radio still available? reconnect the radio, power up and check and see if the antenna port has power on it. the vw53 adapter allows the aftermarket radio to send power along the antenna coax. if there is no power, try the vw10. but if the radio has reception issues, the vw53 will be required.
hope this helps.
mark
Posted By: pts760
Date Posted: December 06, 2013 at 7:33 AM
yes I have the factory radio. What do you mean by antenna port? Is it a pin im testing in the harness on the back of the radio or something else? I'm assuming this will show power when the am/fm is turned on.
Posted By: Ween
Date Posted: December 06, 2013 at 8:09 AM
Antenna port/jack
