2007 mustang v6 radio wire diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136608
Printed Date: May 13, 2024 at 9:09 AM
Topic: 2007 mustang v6 radio wire diagram
Posted By: carsonm12
Subject: 2007 mustang v6 radio wire diagram
Date Posted: May 07, 2014 at 7:03 PM
I currently am having an issue figuring out which wires are what when taking my factory radio out and looking at the two harnesses that connect to it. I am trying to put in an aftermarket radio that requires me to cut off the harnesses so that I can connect the wires together. If anyone knows the color codes to these wires it would be much appreciated I have looked all over the internet and haven't found a thing. My radio is the basic single disc radio (not the shaker) once again it has two harnesses and am completely confused.
thanks for the help
------------- Carson
Posted By: Ween
Date Posted: May 07, 2014 at 8:11 PM
You can try looking here: https://iihs.net/fsm/?dir=40&viewfile=Audio%20System,%20Navigation.pdf
It's for a 2005 but the wiring should be similar.
Posted By: i am an idiot
Date Posted: May 07, 2014 at 8:16 PM
Do not cut the plug off.
If your car has a factory subwoofer, purchase a Metra 70-5521
If it does not have a factory sub, purchase a Metra 70-5520
