2013 impala bose wire input
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=137165
Printed Date: March 03, 2026 at 6:28 PM
Topic: 2013 impala bose wire input
Posted By: talarchevy
Subject: 2013 impala bose wire input
Date Posted: August 27, 2014 at 9:17 PM
OK, New ride,I'm building my system in stages. I have an 2014 Chevy Impala (old body style/8th generation) its the LTZ package w/bose. I want to add 4 ch amp to power my stock bose speakers until i swap them out for better upgrades. I need the wire codes wire diagram for the INPUT section into bose amp mounted under rear deck. I know the stock head unit puts out Low levels into amp then amplifies them. I want to solder on some female RCAs by rear amp to feed my 4channel amp. I know i can buy the PAC AOEM-GM1416 but im only going to run like this for a few months, dont want to drop the cash+ shipping for an adapter which will go into my big bin of other useless adapters. I know speaker outputs(leaving the bose amp)are the same typical GM colors but i need the input side coming from stock deck. Thanks in advance.
------------- Go BIG or go Home it might not be broke, but lets fix it anyway
Date Posted: August 27, 2014 at 9:34 PM
I forgot to mention, at GM bose amp there's 3 plugs, one is obviously for speaker output(Gm standard color code), two Gm las buss data thingy with gnd,constant 12 volt etc, and 3rd plug I'm assuming is low level input from stock deck, just not sure about polarity for soldering in my rca's. Thanks
