2008 cts radio issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138283
Printed Date: May 05, 2024 at 9:15 PM
Topic: 2008 cts radio issue
Posted By: slicksam
Subject: 2008 cts radio issue
Date Posted: January 17, 2015 at 3:59 PM
I have a 2008 Cadillac CTS with a radio problem.
Radio powers up, but no sound. I also know that the flashers + key chime are supposed to play through the speakers. I don't get nothing.
I have a feeling its the OEM amp.
First I have to locate it and then I have to check if there is power going to the amp.
can anyone inform me on the location of the amp and if there is a fuse to check in a certain location?
------------- Testing is the key
Posted By: i am an idiot
Date Posted: January 18, 2015 at 4:15 AM
IN TRUNK ON PASSENGER SIDE BEHIND TRIM
Posted By: sparkie
Date Posted: January 18, 2015 at 9:57 AM
Check for any water leaks that can destroy the amp. Depending on the options of your car, the amp will turn on with a 12 volt trigger (white wire 3rd connector pin 8). Battery is red wire in pin 5 of first connector. If no white wire is present then your amp turns on through data. You will need a GM Tscan tool to check that data bus is working. The best place to start is at the amp. You can check for audio in and power connections.
------------- sparky
