2 channel 4 ohm amp wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138606
Printed Date: May 07, 2024 at 6:19 AM
Topic: 2 channel 4 ohm amp wiring
Posted By: chassis
Subject: 2 channel 4 ohm amp wiring
Date Posted: March 05, 2015 at 1:26 PM
I would like to know,how ohms work on a 2channel 4ohm amp.
Which of the below connections are correct,please correct me as I'm confused with 2 channel and 4 channels.
1) Two 4ohm speakers on each channel
2) Two 2ohms speakers on each channel
3) Two 2ohm speakers in seriers bridged on amp
it makes more sense with mono amps.
------------- Do it once,do it right - This means no short cuts. You never get paid twice for having to do the job twice because it wasn't done right the first time.
Posted By: i am an idiot
Date Posted: March 05, 2015 at 4:46 PM
1 and 3 are fine. Statement #2 only works if you wire them in series.
I am assuming that you are talking about a 2 channel amp that is 4 ohm mono stable.
Posted By: chassis
Date Posted: March 05, 2015 at 10:50 PM
What ohm load is on the amp if I wire it as #1
The stable part,does it means if the amp can only handle a 4ohm load?
Date Posted: March 06, 2015 at 1:57 PM
2 ohm per channel which is the same exact load as a 4 ohm mono load.
