Alpine? Did I get it wrong?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138614
Printed Date: April 27, 2024 at 8:55 PM
Topic: Alpine? Did I get it wrong?
Posted By: hemlig
Subject: Alpine? Did I get it wrong?
Date Posted: March 06, 2015 at 8:00 PM
My System Components in my '06 Toyota Tacoma Dbl Cab:
Alpine:
143BT HEAD UNIT
PDX F-4 AMP
PDX M-6 AMP
SPR60C FRONT SPEAKERS
SPR60 REAR SPEAKERS
IMAGE DYNAMICS 1D10V4 DUAL 4OHM SUB WOOFER
KICKER DUAL AMP WIRING KIT
WHY DOESN'T MY SYSTEM KICK ASS THE WAY I WANT IT TO? WHERE DID I GO WRONG AND HOW DO I FIX IT?
Posted By: spartacus12.lg
Date Posted: March 07, 2015 at 11:59 AM
what does'nt it do? is it not loud enough or does it not hit?
------------- spartacus12
Posted By: hemlig
Date Posted: March 07, 2015 at 11:37 PM
I just don't think it is hitting like it should. Compared to the factory unit replacement (not to mention the money I spent)! I'm no car audio genius as you have no doubt have already figured out. The only thing I had (professionals) do is run and wire up the head unit and dual amp wiring kit. No amp tuning was ever performed. I replaced the speakers my self.
In your opinion, should I be miles above the factory system or just middle of the road like I am getting now? Or, should I be where I want to be and have to turn it down before I enter my neighborhood?
Posted By: sparkie
Date Posted: March 08, 2015 at 3:39 PM
There are many things that could be wrong but unless you have someone check it out that has a good ear, it is hard to say. If the speakers are out of phase or if they are not mounted correctly, then the sound will suffer. The speaker phasing could be wrong if 2 different people wired up the circuits. Use balance and fader to isolate the front and rear speakers. Disconnect the sub temporarily. Listen to just front speakers and use balance to move the sound left and right. Does the bass increase when you move to one side or the other? If it does then one speaker is out of phase. Check the rears the same way and then check left side speakers and right sides to make sure front and rear speakers are in phase. The speakers must be installed so they are sealed. If air in front of the speaker can meet air behind the speaker it will sound poor and can hurt the speaker.
------------- sparky
Posted By: hemlig
Date Posted: March 08, 2015 at 4:52 PM
Really? Door speakers need to be sealed? Why didn't they say that in the installation instructions? Is there a kit or something that I can order specifically for my car? I got most of my installation gear from Tacotunes. Really cool stuff actually.
What about my amp settings and the internal head unit setting? Kind of new to all the lingo. Ohms, and Db settings and yada yada yada. I actually thought it would be plug and play and "maybe" a little tweeking. I may have tweeked the wrong way and I can't figure out where.
Time to spend some more money and get someone who knows wth to do huh?
Posted By: sparkie
Date Posted: March 08, 2015 at 6:21 PM
Proper installation of anything is key to getting the most out of your equipment. Find a reputable shop and get their opinion. It goes back to the old saying "you get what you paid for".
Posted By: itsyuk
Date Posted: March 09, 2015 at 12:08 AM
tell us all about your sub box. what made you decide this was the box you needed?
------------- yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Posted By: hemlig
Date Posted: March 09, 2015 at 12:33 AM
Tacotunes is a dedicated tacoma *amongst other toyota cars and trucks". Everything is custom to your year and of couse, TUNES is what they do. Check it out. I wanted to have a bumpin system but stealth too. The box is what they recommended.
Posted By: itsyuk
Date Posted: March 09, 2015 at 12:37 AM
since you cant give me information i can offer no help.
i am unsubscribing from this thread.
good luck.
------------- yuk
Posted By: oldspark
Date Posted: March 09, 2015 at 3:25 AM
Your system is not plug and play. There is no sensing nor control mechanism.
Vehicles have different acoustics so even if a complete system was specified it would have to be specific to your vehicle.
Even then it cannot account for your taste in music and preferred eq etc.
If you can't tune it yourself - ie, set crossovers etc - take it to professionals.
They should be able to advise if your sub box or volume is appropriate. Same for the side speakers - if they need sealing or s specific cavity volume.
What do tachotunes think about your sound? What crossover frequency have they or you set? Do they think it performs ok?
Posted By: hemlig
Date Posted: March 09, 2015 at 4:16 AM
Sorry, I guess I didn't quite understand what you were asking me. I was reading your e-mail after a round of golf and just gave a quick response. So.... I basically took the recommendations they made from their site. I bought the amp mounting board, the sub-woofer enclosure and recommended 10-in subwoofer from Image Dynamics as they are a re-seller and advocate of their speakers. I bought the amplifiers they recommended too. I am in California and they are out of Texas so communication has all been on-line. So No, they have not heard it. The box is a sealed type and well constructed. Fits perfectly behind the rear seats. Everything was pre-researched and tried and tested so.... why not right? Its possible that their is nothing wrong with what I have to do what I would like it to do. I just have to spend some money (which is probably negligible compared to what I have spent so far) and have a "reputable" car audio shop take a look at it. I love the feed back from everyone. It's like someone is finally listening to me. Alpine has been absolutely no help either.
Didn't mean to offend you earlier, My bad.
Posted By: mrarff
Date Posted: March 19, 2015 at 11:26 AM
In the case of "Tacotunes" they are "recommending" the things they sell because the equipment will physically fit in the truck. No more, no less. Sadly, this does not mean that it is engineered to sound good, great, "kick-ass" or what ever. It simply means that their "stuff" will fit in the cab. No doubt they take great pride in selling "stuff" that fits, but is not necessarily functional. Please do yourself a solid and visit a professional to get you a "kick-ass" system.
------------- "That'll get ya 10 in Leavenworth,11 in Twelveworth, or 5 & 10 in Woolworth". Groucho Marx
