Box for Pyle PLPW15D, Opinions Welcomed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138675
Printed Date: May 05, 2024 at 1:18 PM
Topic: Box for Pyle PLPW15D, Opinions Welcomed
Posted By: 87pontiac
Subject: Box for Pyle PLPW15D, Opinions Welcomed
Date Posted: March 16, 2015 at 4:35 PM
Pyle PLPW15D
1000W Subwoofer DVCTHIELE-SMALL PARAMRTERS
Resonance Frequency Fs: 29.02 HZ
DC Resistance Re: 3.4ohm+3.4ohm
Mechanical Q Factor Qms: 3.94
Electrical Q Factor Qes: 0.5199
Total Q Factor Qts: 0.4593
Equivalent Cas air load Vas: 195.68 L
Surface Area of Cone Sd: 0.082 m2
Efficiency Bandwidth Product EBP 55.8
Voice Coil Over Hang X-max 8 mm
Mms......146.6g
Cms.....0.2052
Rms.....6.78446
Re.....3.4ohm
BL.....13.22220Tm
Dd.....12.72in
Le.....0.00
fLe.....0.00
KLe.....0.00
Xmax.....8.00mm
Vd.....40in>3
no.....0.8945
Znom.....6.000ohm
Looking for some advice for a box. Suggested is 2.1ft3 at 44hz ported (6" diameter by 9' long tube)
Available box size is 35" x 18" x 25"
Subs are only getting 300W (150w/coil)
Listen to alot of bass songs hip hop, Dance,Club......
Thanks for help
Ron
98 Sunfire GTX
Canada
