jl w3v2 wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138698
Printed Date: April 28, 2024 at 8:59 AM
Topic: jl w3v2 wiring
Posted By: localtaggs
Subject: jl w3v2 wiring
Date Posted: March 21, 2015 at 4:44 PM
So i got a jl w3v2 4ohm and didnt notice that the other one was a jlw3v2 6ohm how would i wire that up to a hifonics brutus 1200watt amp. Thanx guys
------------- Localtaggs
Posted By: i am an idiot
Date Posted: March 22, 2015 at 1:13 PM
Are you putting the 4 ohm in place of the 6 ohm? Or are you adding the 4 ohm as a second driver?
Date Posted: March 23, 2015 at 7:24 AM
No i bought them and want to know the best way to wire them up and is it ok to use a 4ohm and 6 together
Date Posted: March 23, 2015 at 9:21 AM
The 4 ohm will be louder than the 6. As long as they are in separate chambers of your enclosure they will be fine. Just connect both positive speaker terminals to the positive terminal of the amplifier, and connect both speaker negatives to the negative terminal of the amplifier.
Date Posted: March 23, 2015 at 9:28 AM
Well before i got a reply....i wired the positives to eachother and negative to eachother than stepped it down to a 1 ohm setup....is that to much for my hifonics brutus 1200 mono
Date Posted: March 23, 2015 at 4:26 PM
You could not have set it up at 1 ohm. A 6 and a 4 ohm coil paralleled = 2.4 ohms.
Date Posted: March 23, 2015 at 4:31 PM
Ok well i watched a video on how to wire them up... so what are the then...duel coil pos to pos neg to neg..connected pos to pos from each speaker and neg to neg from each speaker...to bridged amp....what would they be then?
Date Posted: March 23, 2015 at 4:32 PM
Sorry didnt see the 2.4.....so is that the best way?
Date Posted: March 24, 2015 at 11:32 AM
I noticed no reference to a dual voice coil driver. Which one is a dual voice coil?
Date Posted: March 25, 2015 at 8:08 AM
Both...
Date Posted: March 25, 2015 at 5:27 PM
That would be a 1.2 ohm load.
Posted By: Safe & Sound
Date Posted: March 25, 2015 at 9:35 PM
It's like having a boat with two props that are totally different sizes and pitches. Yes, it will function but not well or efficiently. Get ride of one of the subs for an exact match.
Posted By: sirhutson
Date Posted: March 26, 2015 at 10:13 AM
It will work, just put the subs in seperate chambers. It wont sound as good as 2 subs of the same impedance, but it will work and probably sound pretty good. I would be careful, those amps are pretty dirty and can send out nasty power. be gentle.
------------- Hutson-
Date Posted: March 26, 2015 at 10:15 AM
^^ oh and i hope that this amp is a mono and not a 2 channel.
