Need Chevy Colorado radio wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138839
Printed Date: May 05, 2024 at 9:45 AM
Topic: Need Chevy Colorado radio wiring
Posted By: voltswagon
Subject: Need Chevy Colorado radio wiring
Date Posted: April 19, 2015 at 12:42 AM
Need to find correct harness for my 05 Colorado I4. Ordered one off ebay doesnt work. Couldnt fine one locally either. Now its down to identifying the factory color wire. Need to find out what the red, purple, purple wires is. Well, the red is constant and not sure of the purple. As I was running ohmeter on one of the purple i blew a fuse.
Hopefully I get help before I start on it again tomorrow after fuse installed.posted_image
Dont Drive and Text, but
Do Text Then Drive
Posted By: itsyuk
Date Posted: April 19, 2015 at 4:05 AM
do these help?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Posted By: i am an idiot
Date Posted: April 19, 2015 at 10:35 AM
Which harness did you buy? If it was not a digital harness, did you run a switched wire to the fusebox? If the plug you purchased plugs into the truck you probably have the right one. Do not cut the plug off.
Date Posted: April 19, 2015 at 10:49 PM
EBay #391044831716
Switch wire? Are you talking about acc / ignition switch?
i am an iQiot wrote:
Did you run a switched wire to the fusebox?
The plug fits but the pin doesn't match up.
More research from other help. Decided to but one with module from crutch field $50.
Do Text Then Drive
