2014 Ford STX: need radio antenna amp wire color
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=138857
Printed Date: April 28, 2024 at 4:20 PM
Topic: 2014 Ford STX: need radio antenna amp wire color
Posted By: meetloaf13
Subject: 2014 Ford STX: need radio antenna amp wire color
Date Posted: April 23, 2015 at 12:18 AM
I've installed my aftermarket HU and have everything imaginable installed. I skipped the XM radio antenna Because I'll never use it.
I've tried to pLug the straight blue wire from the oem small harness to a switched line 12 V and several other combos, but I can't get any AM and very few FM radio stations.
------------- 2014 Ford f150 STX
Date Posted: April 23, 2015 at 12:21 AM
Pioneer avh 4600bt.
Metra wiring harness
Metra AXXESS steering wheel control unit
Eclipse 4300 4x75w amp
Jbl components up front
Infinity kappas in back
Posted By: dairyboy3
Date Posted: April 23, 2015 at 1:11 PM
Did you buy an antenna adapter for the am/fm antenna in the truck? I believe on the STX trim it uses the 40-cr10 from metra which is the Chrysler antenna adapter. But I have seen the euro antenna style, 40-eu10 on the Lariat and XLT models in that year.
Date Posted: April 23, 2015 at 2:47 PM
Yes, I went to a local car stereo outfit and they sold me the wrong antenna. After researching it online, I went back and I got the correct part, just about an hour ago.
Problem solved.
Thanks for your reply.
