2008 Cadillac escalade power remote wire.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139044
Printed Date: May 03, 2024 at 8:36 PM
Topic: 2008 Cadillac escalade power remote wire.
Posted By: 1978malibu
Subject: 2008 Cadillac escalade power remote wire.
Date Posted: June 01, 2015 at 9:34 PM
There is no wire diagram for the radio in stall for 2008 Cadillac escalade. I need a power accessories wire please help
Posted By: i am an idiot
Date Posted: June 01, 2015 at 11:14 PM
There is not a switched wire at the radio. What are you trying to do?
Date Posted: June 01, 2015 at 11:21 PM
I have a Bluetooth I simple to install. It has three wire's grd,12v pos and a ing switch pos wire.
12 volt and grd wire easy, but there is no ing switch wire. According to another site I was on.
Date Posted: June 01, 2015 at 11:40 PM
Look just to the left of the brake pedal, on the firewall. There is a junction box, remove the cover, there are several terminals in that box. The one you are looking for is the one at the lower left corner. It is the pin in bottom row all the way to the left side of the box. This terminal remains hot until the door is opened. So the bt will work as long as the radio is powered up.
Date Posted: June 01, 2015 at 11:45 PM
Ok I was told to use the brown wire coming from Ing switch
Posted By: icearrow6
Date Posted: June 02, 2015 at 7:31 PM
DO NOT TOUCH THIS WIRE. it is an accessory wire, but it can't be used to power ANY aftermarket equipment.
Look in the Junction Box "iam idiot" posted.
Date Posted: June 02, 2015 at 8:29 PM
Ok, so just use a spade push it in and thats it
Date Posted: June 03, 2015 at 9:56 AM
Date Posted: June 03, 2015 at 11:35 AM
Pretty much. Your PM sounds like you have the correct terminal. Use a volt meter to verify.
Date Posted: June 03, 2015 at 12:32 PM
I have a safe inline checker with key on power key off grd. Do I need to fuse this or not
Date Posted: June 03, 2015 at 5:46 PM
Yes. 2 amps of current should be plenty enough for your device.
