avh-x3700bhs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=139934
Printed Date: March 02, 2026 at 8:14 PM
Topic: avh-x3700bhs
Posted By: kc2llw
Subject: avh-x3700bhs
Date Posted: December 12, 2015 at 7:24 AM
Hello,
I have a Pioneer radio I installed in May of this year. I love it but very since its been getting cold out I have a problem with it powering up anything under 55 degrees out side and it turns on and off the colder outside it will not even power up once the car gets warm above 60 than it stay powered up. Any ideas???
Thanks,
Steve
Posted By: DYohn
Date Posted: December 12, 2015 at 12:16 PM
Sounds like a defect. I would take it back.
Posted By: kc2llw
Date Posted: December 12, 2015 at 2:55 PM
After 6 moths? Could it be a flakey fuse or bad solder connection?
Posted By: i am an idiot
Date Posted: December 12, 2015 at 7:36 PM
Remove it and check voltage on the Red and Yellow wires of the radio. Use the radio chassis for ground reference, if you have 12 volts on both of those wires with the key in the run position it is your radio.
Posted By: kc2llw
Date Posted: December 18, 2015 at 6:44 PM
Pulling it out tomorrow will update my findings
Thanks,
Steve
