2016 F250 wiring harness
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142024
Printed Date: March 02, 2026 at 6:25 AM
Topic: 2016 F250 wiring harness
Posted By: johnnygaloshes
Subject: 2016 F250 wiring harness
Date Posted: November 15, 2016 at 12:36 AM
I have a 2016 F-250 Super Duty XLT 4 door crew cab and it has the factory AM/FM/CD stereo. I am looking for a wiring harness that will work.
I DO NOT care to keep Sync, steering controls or anything factory simply because sync stinks and i never use my steering wheel controls anyway.
Suggestions?
THANKS!
Posted By: i am an idiot
Date Posted: November 15, 2016 at 8:03 PM
Metra 70-5520 if you are able to locate a switched power source to connect your radio's red wire.
Metra xsvi-5520 if you do not want to have to deal with that.
Date Posted: November 15, 2016 at 11:13 PM
i an finding
Metra xsvi-5520-nav a lot. Is this the same item or is it for navigation
Date Posted: November 16, 2016 at 7:53 PM
It is the same but it also has extra outputs that a nav unit would use as well. Speed sense, parking brake ETC.
Date Posted: November 20, 2016 at 6:43 PM
I appreciate the replies to this topic I have one other question however what will I lose exactly by simply bypassing everything will I still have my door chime my cruise control and all that I know I will lose my steering wheel controls for the radio which I could care less and I will not have the Ford sync working anymore which I could care less about that also but I want to make sure that everything else will still work properly thanks again for your help
