adding an amp and a sub in truck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142143
Printed Date: March 02, 2026 at 8:07 AM
Topic: adding an amp and a sub in truck
Posted By: rodgers
Subject: adding an amp and a sub in truck
Date Posted: December 01, 2016 at 6:19 AM
Hi,
I'm familliar with car steroe install but not adding sub and amp to factory radio. so I want to add a sub and an amp in my truck keeping the Oem radio in it, my truck is a 2016 f150 non sony.
I have an old amp that I want tu reusse to power my shallow mount sub, Alpine mrp-f250, it's a 4x50 watt amp, can I power a sub with this amp? and if I can, what sub is the best for this amp ex: 300w dual coil sub.
I want to tap in rear speaker wire to get signal (rear left + and real right -)my anp riquire rca input, do it exist an line to rca adaptor?
Do I need to connect the remote wire?
for more detail and picture of my amp you can visit this page https://www.f150forum.com/f30/2016-screw-sub-add-help-365261/
Thanks for your help!!
Posted By: wisco_install91
Date Posted: December 05, 2016 at 10:25 PM
Hi there,
You will need something called a LOC (line output converter). This will take the high level signal form your stereo and convert it to a low level. The ones I always install are the PAC ones and never have any issues with them. https://pac-audio.com/productDetails.aspx?ProductId=1184&CategoryID=28 however there are a lot of them on the market that will do the job fine. As far as the remote wire is concerned you will need to tap into a switched 12 volt source (a wire that has 12 volts with the key on and nothing when it is off) I don't have access to the wires of your truck because I'm not at work but I'm sure someone can chime in with that information.
Tell me again about your 5,000 watt amp you got for $99.00
