woofer and amp set up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142627
Printed Date: March 01, 2026 at 9:39 PM
Topic: woofer and amp set up
Posted By: lilisaacray
Subject: woofer and amp set up
Date Posted: February 18, 2017 at 2:18 AM
i have 3 Kicker 10C124 12" 500W 4-Ohm COMP subs. i have a kicker ZX 350.4 amp and a JL AUDIO e4300 amp. Which amp would be best to run these subs. Also how would you wire them to the amp. (parallel or series, bridged or not bridged, each sub individually wired to its own channel). Kinda new and want the best sound with what im working with. Thanks your advice will be much appreciated.
Posted By: DYohn
Date Posted: February 18, 2017 at 10:19 AM
Those are both 4-channel amps. Neither is a good choice for subwoofers. And with 3 x 4-ohm subs, your options are limited. You will need a mono subwoofer amp capable of a 1-ohm load, or drop it to two of those subs and get an amp capable of a 2-ohm load. If you MUST use all three subs and you MUST use one of those amps, connect each sub to its own channel and send the same input to all three channels. Leave the fourth channel empty.
