enclosure building
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142886
Printed Date: March 29, 2024 at 1:21 AM
Topic: enclosure building
Posted By: thebidsocram
Subject: enclosure building
Date Posted: April 20, 2017 at 3:47 PM
Guys,
Newbie here, i want to design a enclosure with a ported vent, but i don't know how much volume requirement to produce good sound of my 12 inches sub-woofer.
any recommendation of volume requirement from you guys with sound enthusiast? I do already check the volume calculator from this and understood how to do it, but i want to know the general rule of thumb how much cubic feet of air space or volume of every inch of a sub-woofer size.
your replies are highly appreciated.
------------- thebidsocram
Posted By: marklar65
Date Posted: April 22, 2017 at 1:01 AM
There is no "Rule of Thumb" on the volume requirement for a size of woofer. The volume of the enclosure will depend on the woofer parameters. Every woofer is built with different materials and methods which affect the output. Post the model of woofer you plan on using and I'm certain one of the fellow enthusiasts will be able to give you the volume/port dia./port length to tune it to the frequency you are trying to achieve. Best of luck to ya!
Date Posted: April 22, 2017 at 1:09 AM
thanks mark,
my sub make is lightning lab model 1XL with 12" diameter, 500 rms.
thebid
Date Posted: April 22, 2017 at 1:15 AM
planned to tune of 35hz.
i did lost my sub manual to find the sub characteristics. even i search it on internet the sub was not much known but here in the Philippines, its popular.
Posted By: DYohn
Date Posted: April 22, 2017 at 11:19 AM
Never heard of Lightning Lab. Follow the manufacturer's recommendations. ------------- Support the12volt.com
Date Posted: April 24, 2017 at 3:57 PM
dears,
here are the specs. mybe you could help me build my enclouse ported.
at least the enclouse volume is enough for me.the rest i can manage
SPECS: lightning lab 1xl
500 watts RMS rated continous power
1000 watts RMS max
dual 2 ohms coil
Double 220oz Magnet (440oz)
12" inch SUBWOOFER
mounting depth 5.75" inch
frequency response 20 Hertz ~ 200 Hertz
pressed paper CONE
extra heavy duty rubberized foam like EDGE
class A solid DIECAST BASKET
SOLID COPPER voice coil
4 pigtails
2.75" inch HIGH DENSITY ALUMINUM VOICE FORMER
extra wide SPIDER
10 Kgs net weight
these only i've got.
Posted By: DYohn
Date Posted: April 29, 2017 at 4:36 PM
There is no information in those "specs" to help decide on an optimal enclosure size or type. Go ask a dealer in your area what they recommend. ------------- Support the12volt.com
