2011 Honda Pilot LX - Split rear output into 2?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143373
Printed Date: March 01, 2026 at 6:21 AM
Topic: 2011 Honda Pilot LX - Split rear output into 2?
Posted By: elsabaw
Subject: 2011 Honda Pilot LX - Split rear output into 2?
Date Posted: July 17, 2017 at 10:55 AM
Just discovered there is no factory plug when trying to install 3.5" speaker in the 3rd row pillar trim in cargo area. Trims EX and above have factory 3rd row speaker in pillar trim. I ran with the assumption all trims used the same wire harness with unused plugs taped off. I have a JVC single DIN going into an Alpine 5 channel amp. I want to use quick wires so that I don't have to run wires from the amp all over the cabin to each speaker. Please advise with helpful suggestions/solutions. Been trying to do this aftermarket install for years but couldnt (family of 6 with young kids posted_image). I thank you for your help.
Tony G
