Switched 12V at Fuse Panel, 2011 GMC Terrain
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144742
Printed Date: March 01, 2026 at 2:43 AM
Topic: Switched 12V at Fuse Panel, 2011 GMC Terrain
Posted By: jh1973
Subject: Switched 12V at Fuse Panel, 2011 GMC Terrain
Date Posted: September 20, 2018 at 11:42 PM
I'm using the stock HU so my DSP gets turned on by a switched 12v circuit in the interior fuse panel.The slot was empty and I added the circuit.The DSP then turns on 2 amps and I now want to add 2 fans to cool the amps.Can the switched circuit handle 2 more loads like that or should I use a relay?I'm not sure how many amps the fuse panel circuit can handle so thats why I'm asking.Thanks!
------------- Rumors of Bob but never Bob......So what is it you tell people you do these days Bob?
Posted By: eguru
Date Posted: September 21, 2018 at 9:13 AM
What car/HU/DSP are we talking about? What are the specs on the fans?
Posted By: jh1973
Date Posted: September 21, 2018 at 9:22 AM
2011 Terrain,stock HU with Zapco Z8 IV processor,2 Zapco STX amps and fans are rated to draw .19 amps.
Posted By: jh1973
Date Posted: September 21, 2018 at 9:45 AM
Just using common sense would tell me that I could easily use the circuit from the fuse panel because the other fuses in the same column are 20A and 10A. The 5 components I'll be powering probably won't even amount to 1A of draw. Is my thinking correct here?Approval from an expert here would be appreciated,thanks.
Posted By: eguru
Date Posted: September 21, 2018 at 12:29 PM
Those are pretty small fans - so you are correct - should work fine on existing circuit.
