2015 Hyundai Sonata, Back Up Sensor Audible Warning
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145445
Printed Date: March 01, 2026 at 4:34 AM
Topic: 2015 Hyundai Sonata, Back Up Sensor Audible Warning
Posted By: IIrjII
Subject: 2015 Hyundai Sonata, Back Up Sensor Audible Warning
Date Posted: June 06, 2019 at 12:59 PM
I installed a 4 channel amp into 2015 Hyundai sonata . The backup sensors audible warning stopped working on it. Is there a way to connect the 4 channel amp and still have the Audible on the back up sensors to work still
Posted By: i am an idiot
Date Posted: June 06, 2019 at 2:38 PM
Where did you catch signal? Front and rear, or just rear?
Posted By: IIrjII
Date Posted: June 07, 2019 at 9:12 AM
I caught the signal from the front. I am using an lc6i for the line out on a stock deck
Date Posted: June 07, 2019 at 9:29 AM
Highly unlikely but they may have injected that into the rear channels. Do you know if it came from the rear? Connect a test speaker to the rear output of the radio to see if this is the case.
Posted By: IIrjII
Date Posted: June 07, 2019 at 3:44 PM
I hooked the speakers back up minus the amp and the audio for the back up sensors started working. The customer also complained that the blind spot beeping stopped audibly working as well. But with the driver door speaker basically back to stock only audio for backup sensors. I'll try tagging another output when they come back.
