2002 Lincoln LS Amp Bypass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145470
Printed Date: March 01, 2026 at 2:43 AM
Topic: 2002 Lincoln LS Amp Bypass?
Posted By: lee@loudhouse
Subject: 2002 Lincoln LS Amp Bypass?
Date Posted: June 15, 2019 at 12:42 AM
hello does anyone know if the amp in a 2002 Lincoln LS needs to be retained? I'm installing a whole new system which includes stereo, speakers, 4 channel, monoblock, and subwoofers. I want to just install the new amps hopefully without having to buy a exspensive bypass harness or anything. can I just leave the factory amp unplugged? and crutchfield recommends a 12 volt to 5volt converter (Axxess-AFDI) which they say is used for adding a new radio to an amplified system to eliminate turn on pop. but I'm not using the factory amp so will I even need that extra ?...and if there is anything else anybody can tell me about this install that might surprise me I would appreciate it. I install electronics all the time but always get stuck when cars have factory amplifiers. thank you any info would help.
LOUDHOUSE
Posted By: mgoetz74
Date Posted: June 15, 2019 at 10:07 AM
no you can do a new 4 channel and not us the factory deck. The 12 volt to 5 volt adapter would be if you are using the factory deck so it doesn't pop when you turn it on/off or change sources
Posted By: i am an idiot
Date Posted: June 15, 2019 at 11:51 AM
The amplifier is only for the factory subwoofer. All 4 speaker wires are behind the radio. Purchase a Metra 70-1771 or equivalent.
Date Posted: June 16, 2019 at 5:32 PM
awesome thank you. so I dont need the Metra 70-5519? the 5519 is just to integrate with the factory amp? because the 5519 comes with extra harnesses. all I need is the 1771?
LOUDHOUSE
Date Posted: June 16, 2019 at 9:29 PM
Correct.
