Bose Low Level, 2011 Chevrolet Silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145540
Printed Date: March 01, 2026 at 2:42 AM
Topic: Bose Low Level, 2011 Chevrolet Silverado
Posted By: jh1973
Subject: Bose Low Level, 2011 Chevrolet Silverado
Date Posted: July 26, 2019 at 4:04 PM
I've got a 2011 Silverado with Bose and saw on the schematics that there are low level audio signals going from stock HU to amp.Can I just tap those and attach RCA's? I mean,does anybody know if those signals are full range and suitable for an aftermarket amp?
Rumors of Bob but never Bob......So what is it you tell people you do these days Bob?
Posted By: i am an idiot
Date Posted: July 27, 2019 at 4:06 AM
It is full range. Probably not enough level to drive an aftermarket amplifier.
Play a test tone somehow, set meter to ac volts. Turn radio up as loud as you feel comfortable with and read the voltage. If you anything over 1/2 a volt you should be ok.   Are you just adding a sub amp?
Posted By: jh1973
Date Posted: July 27, 2019 at 6:44 PM
Thanks for the reply,yes I am just adding a sub amp.The reason I asked was because I did a 2011 Terrain and the stock low levels were putting out 6.6v AC.It was showing that on both my DMM and O-scope so it was accurate.I just wasn't sure with the Bose setups as I'm only familiar with the older GM Pioneer setups.
