Alpine iLX-W650 Not Fully Funtional
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146067
Printed Date: February 28, 2026 at 10:58 PM
Topic: Alpine iLX-W650 Not Fully Funtional
Posted By: Blowntweeters
Subject: Alpine iLX-W650 Not Fully Funtional
Date Posted: March 09, 2020 at 1:29 PM
Installed this headunit lastnight and Can not access all the futures    wiring seems to be correct but no Bluetooth or Apple carplay anyone else have this problem? Appreciate any help thanks
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Posted By: mgoetz74
Date Posted: March 09, 2020 at 4:39 PM
This sounds like a dumb question and im not saying anything bad about you but you have a iphone (with atleast 7.1 firmware) plugged into the usb for the apple car play right? The grayed out boxes usually means that the ebrake is not on, simpy grounding the ebrake wire only works once and it has to see a ground each time the stereo is turned on which is there so your not changing setting while your driving. Alpine blocks out alot more than other manufactures. Few years ago you'd have ebrake and a foot brake input and you had to do a combination of those to get by it.
Posted By: i am an idiot
Date Posted: March 09, 2020 at 8:04 PM
Alpine went away with the footbrake wire. But your problem is the parking brake wire needs to not show ground and then show ground. This will allow access to the advanced features. If you connected it to the parking brake, simply engage the parking brake.
Date Posted: March 12, 2020 at 7:11 PM
The parking brake wired to the parking brake wire on the kpac for 4th he steering wheel control
Date Posted: March 12, 2020 at 7:20 PM
I might have a short in my factor parking brake wire can I just wire a switch to the parking brake wire to a ground?
Date Posted: March 12, 2020 at 9:11 PM
Yes
