Sony MEX-N5300BT, Power Antenna Pin?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146583
Printed Date: February 28, 2026 at 3:04 PM
Topic: Sony MEX-N5300BT, Power Antenna Pin?
Posted By: namyenruoj
Subject: Sony MEX-N5300BT, Power Antenna Pin?
Date Posted: November 29, 2020 at 5:10 PM
Hi There,
I recently purchased this Sony MEX-N5300Bt from Vision and I was hoping the wiring harness comes with 16 pin wires but it only came with 13 wires. I need to know which pin is for my power antenna (blue) the harness that came with it has blue/white for remote.
I will be installing this to my 1998 Rav4
Posted By: i am an idiot
Date Posted: November 29, 2020 at 7:25 PM
They went away with the power antenna wire several years back. Alpine is the only one that still has power antenna and remote.
Date Posted: November 29, 2020 at 7:52 PM
Oh no! Really? I'm using alpine car deck at the moment and it comes with blue wire and blu/white. Do you know if one of the pin from my harness will give out 12 volts when you switch to radio? I don't mean the remote wire ( blue/white) if not then i will have to get use to it. Thank you again
Date Posted: November 30, 2020 at 4:14 PM
Yes, really.
Posted By: wirewise
Date Posted: December 01, 2020 at 6:50 AM
According to Sony, it would be pin #6. 16-pin wiring harness for the MEX-N5300BT: https://www.sony.com/electronics/support/mobile-cd-players-digital-media-players-mex-series/mex-n5300bt/articles/00025257
~wirewise~
Date Posted: December 01, 2020 at 9:49 AM
Take a diode or resistor and stick the leg of it into the 3 available spots you have on your harness and use a volt meter to see if one of the 3 have 12 volts on it when the tuner is on and no voltage on it when listening to another source. Let us know what you figure out.
Date Posted: December 01, 2020 at 10:08 AM
At first I was just mildly skeptical of their info. I decided let's see where pin 6 is. After seeing this i am mo longer mildly skeptical.
Tried posting image from my phone. Give me a minute to email it to myself.
Date Posted: December 01, 2020 at 10:11 AM
posted_image
Date Posted: December 01, 2020 at 10:53 AM
Above photo is of a 4200bt, the only difference is there is not an illumination wire on mine. They said white was on pin 1.
Date Posted: December 06, 2020 at 7:11 PM
posted_image
If i put wire in one of these empty space will it work? I use my volt meter and when i turn on my radio non of those spare pins I don't get 12 volts at all
Date Posted: December 06, 2020 at 7:13 PM
I looked at the sony website by wirewise but It does not match with my Dony harness that came with my unit. Where is pin#1 and pin #16?
Date Posted: December 08, 2020 at 7:49 PM
I checked the n4200bt today. Of the 4 blank spots on that plug, there was no power antenna connection.
Date Posted: December 12, 2020 at 3:05 PM
I finally installed my Sony MEX-N5300BT and with my addition with a power antenna after market and remote Alpine amplifier for my 1998 RAV4 I can only use Blue/White no Blue wire from deck harness, I've notice that when the car still running and I decided to turn off my Sony deck of course power antenna and remote amplifier turs off and then when I turn off my engine somehow my power antenna and remote amplifier turns on and goes up again for 15 seconds and comes down and turns off finally. What could it be the problem.
Thank you
Posted By: geepherder
Date Posted: December 13, 2020 at 4:17 AM
Some amps have a delay built-in to prevent a "popping" sound when powering on/off. I wonder if this is the case here and it's backfeeding the power antenna.
You could try installing a diode on the remote turn on at the amplifier. Connect the striped side to the amp.
Date Posted: December 13, 2020 at 6:33 AM
Thank you Geepherder. From deck harness blue/white I should connect it to my power antenna first, then a diode with stripe to power amplifier all in series right? What size of a diode do I need?
Date Posted: December 13, 2020 at 8:08 AM
Since it's hooked up, it'd be simpler to just install it at the amplifier. Disconnect the amp turn on lead, connect a diode in series and reconnect it to the amplifier.
I just use generic 1 amp switching/rectifying diodes. While they were still in my area, I could buy 25-packs from RadioShack. I don't know if you have them near you, but I still buy locally from Fry's and Microcenter. If you don't have a similar store nearby you can always order online- check eBay and Amazon.
Date Posted: December 13, 2020 at 11:26 AM
Thank you so much geepherder. I will do that and let you know.
Date Posted: January 10, 2021 at 4:54 AM
I finally pulled out my deck again and I found out the deck itself gives out 12 volts again to the blue/white wire after shutting down my unit and it also gives out beeping sound for few second. I know Sony brand does this. That is why my after market power antenna goes up again for a few second and goes down. Is there a way to dis able this feature from Sony.
Date Posted: January 10, 2021 at 8:56 AM
If you want, you could switch the power antenna connection to the red accessory wire. Then, whenever the key is turned to accessory, regardless if the radio is on, the antenna would be powered. When you turn off the key, the antenna would power down.
Posted By: the12volt
Date Posted: January 10, 2021 at 9:00 AM
Or use an SPDT relay as follows to accomplish the same thing when the key is turned off and still be able to lower it when you turn off your head unit.
86 to Blue/White from Sony head unit
85 to ground
87 to accessory 12V+
30 to power antenna remote lead
posted_image the12volt • Support the12volt.com
Date Posted: January 10, 2021 at 10:44 AM
Press and hold source button till the time is displayed. If you tap it too long the display will go blank and you will not be able to get to the following menu. Tap volume knob to get to the menu, turn vol knob to get to General settings. Tap and then turn to CAUT ALARM. Whole word is not displayed, but you will get it. Tap then turn that to off. This will stop the beeping and the powering of the antenna wire.
Date Posted: January 10, 2021 at 11:00 AM
Thank you all. You guys are awesome. It all make sense all your comments. I will try them out and see what happens. Happy New Year guys.
Date Posted: February 06, 2021 at 11:09 PM
Just to give you guys uodate. I did take "i am an idiot advice" to disable the CAUT ALARM and now it works according to what i want. When the unit is turned on my power antenna goes up and when the unit is turned off antenna goes down completely. Thanks for all your advice
