2003 Jeep Grand Cherokee, Add Powered Sub To Infinity System
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147340
Printed Date: April 16, 2026 at 12:34 AM
Topic: 2003 Jeep Grand Cherokee, Add Powered Sub To Infinity System
Posted By: kw4tx
Subject: 2003 Jeep Grand Cherokee, Add Powered Sub To Infinity System
Date Posted: May 04, 2022 at 10:24 AM
I have a 2003 Jeep Cherokee Laredo with an Infinity system. I want to add some low-end to the system. I don't want the teeth-rattling window bowing system. I am keeping the factory radio
My question is can I tap into the Infinity amp to run stuff like remote wire and use high-level inputs to the sub/amp
I will of course use a separate ground and power wire
If so does anyone have a wire code? TIA
The sub/amp I am planning on using has high level inputs
