2014 WK2 Jeep Grand Cherokee, Built In Microphone Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=148063
Printed Date: February 28, 2026 at 9:07 AM
Topic: 2014 WK2 Jeep Grand Cherokee, Built In Microphone Wiring
Posted By: ron9mm
Subject: 2014 WK2 Jeep Grand Cherokee, Built In Microphone Wiring
Date Posted: June 25, 2024 at 3:56 PM
Hello all. First time poster here.
I’ve got a 2014 WK2 Jeep Grand Cherokee Summit (push to start). It has built in microphones into the rear view mirror (two bumps on the top, left and right). I recently upgraded the stock Uconnect head unit to CarPlay by using an aftermarket kit that added a circuit board to the radio itself, and linked to an external module to provide the CarPlay.
The problem is that the external unit doesn’t utilize the rather nice built-in microphones. It uses a low quality microphone that has a mono 2.5 mm plug that goes in the back of the aftermarket unit. What I want to do is the following:
1) locate microphone wires into the stock head unit
2) create an “extension cable” - a 6” male to female cable that passes through pin 1 to pin 1, pin 2 to pin 2, etc.
3) splice into the appropriate wires to create a mono, 2.5mm plug to put into the aftermarket module.
Is this even possible? I haven’t been able to wrap my head around the consequences of going from two (possibly stereo) microphones into one mono input.
Thanks in advance. All help, suggestions, alternatives, and comments are appreciated.
2014 Jeep Grand Cherokee
5.7l V8
Summit Edition
Posted By: meccano
Date Posted: December 18, 2024 at 8:06 PM
Did you make it ?
Found something good ,
The microphones are connected to the Bluetooth module down on the left side of the steering wheel.
Please let me know if you van make it!
posted_image
Meccani Egypt
