Firewall drilling on my ford taurus 93?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15185
Printed Date: May 31, 2024 at 6:22 AM
Topic: Firewall drilling on my ford taurus 93?
Posted By: manning58
Subject: Firewall drilling on my ford taurus 93?
Date Posted: June 19, 2003 at 10:34 PM
Im wondering if somone could tell me around where on my Ford Taurus 1993 to drill for my power wire, I dont want to damage anything. Please help!
------------- Niko Suave
Self Installer
Posted By: Tcole
Date Posted: June 20, 2003 at 9:34 AM
Try under the dash/drivers side, there should be a small area were a clutch would be mounted if you had a manual. You will need to take out a small amount of firewall insulation that hides the area. Check it out, its worth a try.
Posted By: djfearny2
Date Posted: June 20, 2003 at 1:46 PM
listen your will be ok just look at the engine side of firewall and match it by eye on the under dash side (drivers side) than drill hole you'll be ok
------------- Jon
Installer/Help Technician
---coral springs florida---
