I have 3 JL 12 w3 subs dual 4 ohm. I recently purchased a custom box for my camaro for these subs, it is an open chamber enclosure with 3 cubic ft. of space. I just sold it and bought a 1999 Chevy Tahoe. I want to get a different box because I now have more space and that is my problem. Would a bigger sealed box benifit me as far as more volume and maintaining the same sound quality. Would a ported box kill my s.q. What would you guys do? I don't want to blow another 300 bucks for a spec box if it wouldn't benifit me. The amp I am running is a soundstream rubicon 10.2, big 1000 watt amp.
For a sealed box, you'd want something has 3.375 cu. ft. of internal volume; for a ported box, you'd want one with 5.25 cu. ft. of internal volume, and 3 ports that are 4" in diameter and 16.2" long. According to JL, a triple sub enclosure just requires 3 times the amount of internal volume and 3 times as many ports, so that's how I came up with the above figures.
They don't really mention which type of enclosure will sound "better", but then again that's always a pretty subjective thing anyways. They do say this at the very beginning of the manual though:
Both types of enclosures will give you excellent sound quality and
low-frequency extension. The sealed enclosure is a better choice if space is extremely tight, but the ported
enclosure will produce 3dB more output at the same power if you have the extra space to work with.
Ethan
Donate to the12volt.com
Will a ported box kill my sound quality? I know it will be louder but it doesn't matter if it sounds like a fart. I could sacrifice some s.q. for spl but not too much. Will a larger sealed box than I already have sound the same or different?
It's really hard to give a definite answer cuz as you know there's so many variables and what sounds good in one vehicle can sound like poo in another vehicle. I think a ported box built to JL's recommended specifications would not suffer much of a SQ hit at all, or else they would have noted that in the manual. It might go a little deeper too, but once again that's hard to say for sure.
I don't know how much (if any) of a difference a slightly larger sealed box would sound compared to your 3 cu. ft. box. If it'll cost you $300 to get a new box then I'd say just stuff some poly-fill in your existing box and it'll act like it's pretty darn close to a 3.375 cu. ft. box; and it'll cost a whole lot less obviously.
Ethan
thanks for your help. The guy at the stereo shop said that the ported box would lose a lot of s.q. but the spl would make me dump in my pants. I think I will give the big ported box a shot because I have never had one before and I want to try something new. My box is already stuffed with polyfill but my system sounds like it is being held back by a small box. Thanks again, Mike
true a ported box will pound harder and actually can be more efficient then a sealed if tuned correctly. If you are worried about port whistle you can go with square ports that cut down on this, and i have a friend who had 2 JL12w3's in his Geo in a sealed then had them in a ported in his blazer and he didn't lose very much sq but they beat harder and deeper, but he hasn't got them hooked up to a SPL mic to see the difference yet.
