need help with 2003 silverado ss
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18198
Printed Date: May 12, 2026 at 7:13 PM
Topic: need help with 2003 silverado ss
Posted By: lncmarkviii
Subject: need help with 2003 silverado ss
Date Posted: August 28, 2003 at 10:45 AM
just purchased a 2003 silverado ss and would like to put a stereo in it. it has stering wheel controls as well as the driver info center controlls. does any manufactor make a peice to intergrate the gm cbus 2 so that i don't have a problem with the computer features, i don't care so much about the radio controlls on tge steering wheel do i don't want to loose my drver info, door chime, or other features
Posted By: Sweekster
Date Posted: August 28, 2003 at 12:25 PM
You may want to check out Peripheral Electronics. They have alot of stuff for class 2 wired GM cars. ------------- Duane...
If you think you're confused, imagine how you feel.
Posted By: SnomanF150
Date Posted: August 28, 2003 at 4:01 PM
Metra and Soundgate both have the piece you need.. it's just a chime adapter that has a multiplex wire and power into it.. also has a acc wire for your aftermarket radio.. you'll notice that the factory harness has no accessory.. they both work well..
there are also adaptor from peripheral for the sterring wheel audio buttons.. I believe you will need a radio with remote control capibilities..
Posted By: zargon
Date Posted: August 28, 2003 at 4:41 PM
is your driver info on the dash or on the radio display, on a escalade 2003 we did the info was in the insturment cluster and we used the above mentionede parts to intergrate, but if the info is on the radio display you will have to keep the radio in the truck to take advantage of them.
------------- zargon ruler of estranorth
Date Posted: August 29, 2003 at 10:36 AM
it's on the dash, thanks for the help just wanted to make sure i wouldn't have any proplems
