3 subs 2 amps
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18350
Printed Date: May 10, 2026 at 8:26 PM
Topic: 3 subs 2 amps
Posted By: Ketel22
Subject: 3 subs 2 amps
Date Posted: September 01, 2003 at 6:07 PM
what is the best arrangement for three subs and two amps, the subs are Alpine R15's and the amps havent been bought yet. i was hoping for somebody to recommend some.
Quad L Handyman services
Posted By: Velocity Motors
Date Posted: September 01, 2003 at 6:16 PM
Are these the 2 or 4 ohm DVC's ??
Posted By: Ketel22
Date Posted: September 01, 2003 at 6:19 PM
they are 4 ohm dvc i figured 2ohm would require too much money
Date Posted: September 01, 2003 at 6:35 PM
You are looking at 500 watts RMS each so you will need an amp that can handle a 2.66 ohm load and you should wire it up like this:
posted_image
The amp should be able to put out some serious power though. Most digital amps manufactured can handle this load but make sure that the input sensitivity of the amp can handle most 4 + volt output RCA's from processors & HU.
Posted By: Ketel22
Date Posted: September 01, 2003 at 9:08 PM
i was looking for a way to use two amps with three subs
Posted By: pervitizm
Date Posted: September 01, 2003 at 9:25 PM
Why don't you just use one good amp with the three subs instead? In the end you'll wind up saving a lot more money that way.
Pervy
live & die 4 tha luv of BASS!!!!
Date Posted: September 01, 2003 at 9:50 PM
pervitizm is right. Getting one good amp will save you installation time as well as money in the end. If you still want to use 2 amps, then you will have to get a pair of identical digital amps otherwise you will run into alot of problems. It's like getting two identical twins to have a tug-o-war.............. unless they are identical in every way, one will end up being stronger than the other and this holds true for amps, so it will give you mixed results.
Posted By: Ketel22
Date Posted: September 01, 2003 at 10:05 PM
in that case what would be better to buy, three 500w  amps or a 1500w amp, both need to be rms
Posted By: MAXST
Date Posted: September 01, 2003 at 10:12 PM
https://thezeb.com/caraudio/audiobahn_specials.html#audiobahnamps
top one. model #:  A2200HCX
I need quality equipment, feel free to donate.
Posted By: wvsquirrel
Date Posted: September 02, 2003 at 4:08 AM
(1) 1500w amp would be easier (and probably cheaper) then using (3) 500w amps.
Maxst, any reason why you suggested the A2200HCX? Unless I read the specs from Audiobahn wrong, that amp is only rated 800 x 1 @ 2ohms. With (3) 4ohm DVC's he'll be running at 2.67ohms, and that's seriously underpowering the subs.
The closest amp that Audiobahn makes that I could find is the A18001DT, which is rated 1200 x 1 @ 2ohms.
Some other suggestions...
Rockford Fosgate Power 1500bd or Power 1501bd. Both are rated at 1500 x 1 @ 2ohms (based on a 14.4v electrical system, but I have yet to see an RF amp that didn't perform above their rated specs).
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
Posted By: Ketel22
Date Posted: September 02, 2003 at 4:15 AM
squirrel, may  i ask where the cheapest price to buy a rock ford would be, im not paying for the amp but i would still like to keep it cheaper for my mother! :)
Posted By: BulletTooth
Date Posted: September 02, 2003 at 4:18 AM
I know HIFONICS and SOUNDSTREAM make amps that you could hook up in Master-Slave arrangement, so even though you have 2 amps you can run them both to one speaker, or in your case to 2 speakers hokked up as one. The Hifonics is 1000W RMS 1 OHM stable, and the Soundstream is 900RMS 1 OHM stable. I've tried both amps and they are both very good ones.
Date Posted: September 02, 2003 at 4:23 AM
If you buy from an Authorized retailer you can expect to pay at least $800+ for either of those 2 RF amps. With that you get the "true" RF Factory no-questions-asked warranty.
Authorized Rockford Dealers
Scroll down to the bottom of the page on the left hand side for the dealers section...
You can also search on-line from non-authorized dealers (like Ike Sound). The prices are about 1/2 as much as an authorized dealer, but you don't get the factory warranty
Squirrel
