illumination where disc loads?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18370
Printed Date: May 10, 2026 at 5:17 PM
Topic: illumination where disc loads?
Posted By: aggie altima
Subject: illumination where disc loads?
Date Posted: September 02, 2003 at 2:17 AM
When i eject a cd out of my dvh-p5000mp, it goes into off mode where only the time is displayed, and the green light where the disc loads turns off, so i can't see where to load the disc. I thought that the illumination wire (black and orange on my 2000 Altima) was the problem, but it still doesn't work. Also, the deck is supposed to be dimmer when i turn my headlights on, but that doesn't work either.
I don't know if this is it, but there is an orange wire that isn't connected on my factory harness, i think it said illumination ground or something with ground. Is that the problem? If so, what wire do I connect it to?
Thanks for any help.
Posted By: Ketel22
Date Posted: September 02, 2003 at 3:32 AM
if it truely is a ground wire just ground it any where on the frame where there is no paint.
Quad L Handyman services
Posted By: wvsquirrel
Date Posted: September 02, 2003 at 3:34 AM
The illumination wire from the headunit should be ORANGE / White (Orange with a White stripe). According to the12volt's wiring database, the OEM dimmer lead for a 2000 Nissan Altima should be RED / Yellow (Red with a Yellow stripe). Try connecting the headunit's illumination wire to that wire instead.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
