1990 plymoth voyager van
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18812
Printed Date: May 04, 2026 at 8:46 AM
Topic: 1990 plymoth voyager van
Posted By: eazykill
Subject: 1990 plymoth voyager van
Date Posted: September 11, 2003 at 9:22 PM
i have a 1990 plymoth voyager van, and i was going to put in a head unit but i didnt have a wire harness, so i was going to just wire the speekers manualy.  this is were i need help cause the factory speekers are from infinite and have built in amps in the speekers and four wires going in them.  any one know about that type of system please help
Posted By: Sweekster
Date Posted: September 12, 2003 at 10:15 AM
The 4 wires on the speakers you mentioned, if two of them are thicker than the other 2 then those are probably the power and ground.  The smaller ones are probably the speaker connections.  Do you not have a wiring harness in it all?  If not, I would suggest replacing it with an OEM replacement harness.  Then all you would need is an adapter harness for the head unit.   But if you want to just wire it in you could use this diagram for the pin out locations.  You also may need  the simplified diagram as well.  Hope that helps.
Duane...
If you think you're confused, imagine how you feel.   posted_image
